My engine is a johnson 85 V4 Hydro Electric drive 1969 the engine will run perfectly then appears to jump out of gear. the engine continues to run but the teltale stops squirting water. i have replaced the gearbox with a second hand one but it still has the same intermitent problems.<br /><br />Where the main shaft pushes into the back of the engine could this be rounded of or worn?
