Johnson 88 spl water flow question
JEWHALER
I just removed the lower unit and resealed it with all new water pump/housing and and all new lower unit oil seals. I havent seen the engine run for about a year and I can't remember if water is supposed to be running out of a certain spot. Its running out of the hole up top and the other holes down on the lower unit but its running out of a weird spot that I don't remember it doing. Its has water coming out of the midsection area.I'm assuming maybe the water intake pipe isn't sealing. I did not pull the pipe out and replace the top seal. Only the seal at the bottom at the water pump is replaced. I'm attaching a YouTube video link so you guys can see what I'm talking about. If it's normal then I'll just run it. I'm selling it soon anyways because I got a new hewescraft. And advice I would greatly appreciate.
https://youtu.be/hbJMnm_73QQ
