Philupay89
- Sep 3, 2018
- 10
Hey all, I’m new to the site and fairly new to boating in general. I picked up an 89 Glassport with a 89 Johnson 88spl outboard. It’s ran pretty good most of the summer up until recently. I replaced the battery a month or so ago, and just replaced a trim/tilt relay because it was going bad and causing the up tilt to intermittently stop. The relay seems to fix the tilt issue, but now I have a different problem. I was out on the water yesterday, in which the boat ran ok for the most part. It started right up and seemed to idle ok after it was warm. Zipped around for a bit and then went to the sand bar. After we attempted to leave, the boat started acting up. It would start, but once I put the idle lever down the boat would really run sluggish and eventually stall, especially when applying throttle.
I noticed at home that I apparently didn’t attach a wire back to the battery after putting in the relay. It was a wire that went to the horn and nav lights. Idk if that would effect anything or not? Also, when I took the engine cover off I noticed a wire that is disconnected that seems to go into the cylinder? Could this be causing a problem and does it need plugged back in? I have a picture attached for reference. Any help would be greatly appreciated! No I have not checked compression or spark, but it seems to be getting fuel. I just don’t understand why it starts, but then runs crappy after lowering idle and attempting to throttle up. Thanks in advance for the advice!
