Okay, we are going tonight to go look at a 1988 Johnson 88SPL outboard to replace our 1987 E40ELCUD - Evinrude VRO outboard (40hp) in our 1985 pontoon boat.
Will there be much issue with making this swap?
the VRO was a direct oil injection? Will we have to be mixing the fuel/oil for the 88SPL?
Right now on the boat there is a seperate tank for oil. There are regular external fuel tanks.
Will the controls be the same?
Will I be running into any other potential problems? The guy says it is not power trim & tilt, which is fine because the current motor is not also. He has a 1984 90hp Johnson also that has power trim & tilt (and I believe it is a VRO), but he is asking $400 more for it.
Thanks
Melanie
Thanks
Melanie
