johnson 9.5 1968
younggun
I purchased a 1968 johnson9.5 on monday and took it out for the first time yesterday. It started on first pull at the landing but i put it in reverse and i had to rev it a lot higher than i would think to get it to move but it did back up slowly. We got out in the river and put it in forward to head up river and all it would do was rev up and not go anywhere so we tried reverse and again nothing. We had to call a friend to tow us back because we floated down river and the current was to strong to paddle. Anyone have an idea what it could be? Could the hub in the prop have spun?
kfa4303
Banned
Re: johnson 9.5 1968
Hi younggun. Welcome to iboats. It could be a few things. You may have a spun prop and/or a broken shear pin. Either of which could cause the motor to rev without the boat moving. To check, remove the cotter pin holding the prop cone in place, then remove the prop cone. The propeller should then slide off of the prop shaft. If your motor has a hubbed prop, you will most likely have a stainless steel "drive pin", rather than a soft brass "shear pin" which are found on un-hubbed props. If the shear pin is broken, you simply replace it and go on your way. You can buy brass rod at many hardware stores like ACE and cut as many pins as you like. If the drive pin is broken, you'll probably have to order a new one. If the pin looks ok, you have to test the prop for a spun hub by scribing a line across the back of it with a Sharpie and taking it back out on the water. After running at WOT, remove the prop and check the back. If the horizontal line you scribed across the back is no longer level, then the prop is spun in which case you'll need to have it re-hubbed at a prop shop for about $40. However, you may also simply not be going into gear properly. I would check the shift rod connection for starts. If that's ok, you may have a bad/worn clutch dog, which is fairly common. To test it, with the motor off, put it in FWD gear and rotate the prop clockwise by hand. You should feel it engage after about and 1/8-1/4 turn. Repeat the procedure for REV. If the prop engages, that's a good sign, however no guarantee that the clutch dog is ok. The only way to be sure is to take the gearcase apart and visually inspect it. Give these tricks and report back. Here are some handy links to help out.
http://www.marineengine.com/parts/johnson-evinrude-parts.php?year=1968&hp=9.5&model=MQ-14E
http://www.duckworksmagazine.com/06/columns/max/index6.htm
younggun
I took it out just now and it goes into reverse and reverse works normal but forward doesnt work at all. The prop doesnt start spinning
younggun
Well i left it in the water in our pond and just went out there and now reverse doesnt work at all either. Any ideas? I brought it back to the house to work on it
younggun
If it is the clutch dog, will i have to buy a new one? Or is there something i can do to the existing one
geoffwga1
Have you taken off the prop and checked the shear pin yet?
younggun
Yes the pin is still in good shape. I checked it before i left the water
Daviet
Did you check the prop hub to see if it was spun?
younggun
Yes i checked the prop hub earlier today to see if it was spun and it wasnt
Daviet
If the hub and drive pin are ok, and the shift linkage is connected properly, it sounds like you have some lower unit or drive shaft problems. It might be time to pull it apart and check things out.
