dance all day
- Jun 15, 2003
- 16
is it possible to turn the fuel pump upside down<br />and still have it run ok? Because i did this because the fuel hoses were getting kinked when the cover is on the motor ,not a lot of room there<br />but now it starts up but quits when you put in gear and rev it up a bit,starves for gas.<br />the hose from the pump to the carb is a clear hose<br />so i can see the gas in it but its not full all the way.only if you prime it ,it fills right up<br />but when you start the motor it lose's some<br />it looks like it jumping back and forth in the gas line.Is the hose from the pump to the carb<br />supposed to be full at all times?<br />i'd like to use the motor next week and would welcome the help to figuire this one out.<br /> <br /> dave.
