dance all day
- Jun 15, 2003
- 16
just bought this 9.5 hp i believe its a 70<br />when you hold onto the lower unit it moves about an eight of an inch {loose} is this normal?<br />if i twist down the throtle to stop i can see the motor moving a little bit back and forth.<br />is there motor mounts on these models or did someone forget to put some bolts back in it??<br /><br />any help would be great <br /><br />alsoi drained the lower unit and lots of water<br />{clear} and black gear oil came out<br />is there a seal that needs to be replaced?
