johnson 9.9 4 stroke
mikek
i wasn't getting fire from the spark plus. ichanged the ignition switch. i don't seem to be getting 12 volts to my power pack. any ideas? thanks
JB
Re: johnson 9.9 4 stroke
Hi, Mike.<br /><br />What year Johnson 4 stroke do you have? <br /><br />It is likely that your kill switch (different from ignition switch) is preventing 12v to the powerpak. It is the one you hook your lanyard to.<br /><br /> :)
JB
Hi, Mike. Well, I guess you'll need to get a voltmeter and trace the circuit to see what isn't doing what it is supposed to do.<br /><br />Good luck. :)
jegervais
In 1998, Johnson built two different 9.9 4-Strokes, a 211cc and a 305cc. Both use a cdi ignition system, neither requires 12 volts to the power pack. Both systems use a charge coil, which produces the operating voltage which fires the plugs. The smaller one uses a sensor coil to control spark timing, the large bore uses an optical sensor, which is powered by a power coil. <br /><br />The appropriate service manual and test procedures are required to trouble shoot any ignition system or, you're just going to end up replacing parts until you hit the right one.<br /><br />A total "no-spark" situation can be caused by the stop circuit (the switch or the wiring), no output from the charge coil, no output from the sensor coil (or optical sensor), or a bad pack. The big-bore with has the optical sensor built into the pack.<br /><br />What do you have??<br /><br />-John
