thatone123
Banned
- Mar 7, 2009
- 707
I tested the under flywheel components which are a typical green and black OMC coil and a beige colored small coil. Thought that because the wires had current coming thru from a test light they were good. After trying out a few spare CDI's I had laying around and none of them working I am back under the flywheel for the 3rd or 4th time suspecting those coils. Got out the old CDI troubleshooting guide and tried to do my best with that being electrically challenged as I am. Finally found the diode reading on my meter and got no reading and also no resistance readings either that now makes me think those under flywheel coils/trigger are the problem even though both coils look clean and in top condition. Get current through the ignition coils on the outside of the motor and don't suspect them as IT seems one would fail and not both. Spent all day on this to no avail.H-E-L-
P
P
