Have a 1984 Johnson 9.9HP & the throttle shaft on the tiller is frozen. I'm not sure of the exact names of the parts, but there is a rod which connects the throttle twist grip on one end of the tiller to a gearing mechanism on the other (gears on the end of the rod mesh with gear linkage in the engine). The problem seems to be at the geared end of the shaft ... everything else seems to be free. The rod passes thru a hole in the tiler assembly just before the gears & appears to be frozen (corroded?) in this hole. I've used penetrating oil for about a week, but it hasn't made a difference. Suggestions please .. I haven't used heat yet. There's not much room to get a vise-grip on the rod. I'm concerned about damaging the gears if I apply leverage on these.
