flipper575
- Aug 7, 2001
- 1
Hello. I have jonson 90 -78 V4.<br />Im asking how the carbs are connected.<br />I start the motor and then take off the left side (watc behind) sparkcables. Motor runs at same speed (idle). Then i check is there spark. There is good spark.<br />Is it possible that upper carb is for right side cylinders an the lower for leftside.<br />Or how is possible that right side works and left not. <br />Can it been fuelpump that is broken. If i check the fuel pressure what it should be?<br />Have anybody replaced the orginal pump with automotive (electric) pump?<br /><br />Waiting for your help.<br />
