ARTandWATER
- Jul 23, 2010
- 3
year 2004 motor
model J90GLSRM
starts fine.
runs smooth to about 25 mph , then somewhere above that speed power cuts off and on; not a bog, feels more rough like a misfire.
pulled the plugs to check the gap since I just replaced them two weeks ago (checking the other person's work)
bottom port side plug had a bit of black on it.
cleaned the carbs
bottom port side a bit dirty, but nothing out of the ordinary
next thought is the Stator or Power Pack since the engine was underwater last year.
It is a summer camp's boat, and I did not work with it last year, so did not sink it or fix it when it sunk.
Anything else I should check?
Thank you.
model J90GLSRM
starts fine.
cleaned the carbs
Thank you.
