duke714@hotmail.com
- Aug 18, 2007
- 3
I recently replaced my lower unit with NOS from an independent dealer. I had some issues getting the shift arm in the LU tied to the motor but got it all together. I've tried starting it only to get slow cranking what you would get from a low battery. The battery is brand new and fully charged.
Also, the shift cable is a bit off as when I put the Shift handle in neutral, forward is still engaged. I can mess around with this though to get it in neutral and can attempt to start it, to no good.
I've mentioned the LU cause I' guessing that is the source of the problem. Everything worked fine previously. Can you help?
Thanks very much,
Geno
Thanks very much,
Geno
