Seabiscuit_1
- Aug 3, 2007
- 12
Hello All
Thanks for all he great info on the site. 6 months ago I had two 1965 90HP Johnson Meteor II motors each with problem that kept them from running. So, armed with a repair manual and naive confidence I completely disassembled them both and created 1 working motor and a lot of extra parts. The ?new? motor starts and runs great. It does however, seem to run a bit rough in the lower RPMs. When I rebuilt the carb I initially set each of the low speed needle valves to ? of a turn open as the repair manual said. It didn?t however explain a procedure for fine tuning them.
So my question is (finally), what is the procedure for getting the carburetor dialed in just right and what do I look for when I tune the low speed needle valves? To complicate things, the carburetor actually has 4 low speed needle valves (1 for each cylinder). The ? open setting is good enough for the motor to run, but I would think a bit of fine tuning of each cylinder would be helpful.
Thanks for the help everybody!
