catbones
- Jul 15, 2012
- 319
Hi,
Just doing some work on the boat today, a 1967 Starcraft Jet 15' footer from what I found out the other day and not 16 foot. LOL or may e I should measure and not believe a half torn info plate.
Anyways, for the motor controls I've got something that looks like this;
http://www.ebay.com/itm/Johnson-out..._Accessories_Gear&hash=item19d48e86a9&vxp=mtr
Now I hate, specially when I'm coming up to the ramp or dock that I need to shift forward, neutral or reverse and then control the gas. It also shifts really hard and sometimes being new at this, I forget and shift without lowering the rpms below half down from full throttle. Now I see some starcraft boats with just one controller like this;
http://www.ebay.com/itm/BRP-Johnson..._Accessories_Gear&hash=item337af74401&vxp=mtr
So that said, can I convert my 33 1969 Johnson outboard to use the second one from the links above. How do I shift forward and backwards, is it a level or buttons on the handle or something. Can someone explain if that is even possible to have easier shift or automatic shift?
Thank you
Thank you
