Johnson fuel pump
Late Nites
is there anything I should know or do before I attempt to replace the fuel pump on my 95 johnson 112 spl. I've never done this before, but i'm pretty sure i should be able to handle it. I THINK...<br /><br />Thanks for any help.
OBJ
Re: Johnson fuel pump
Pretty straight forward job Nites.....remove the inlet and outlet lines, remove the two screws holding it to the block. Clean the area around the hole that pulses from the block come through. Mount new pump with new gasket. Make sure the fuel lines are tight on the connections. Open a long neck Bud and enjoy.
Late Nites
Does the gasket come with the pump or should have I ordered this seperate? I heading down in 30 minutes to put the new pump on, I think.
