Johnson Fuel Pump
JoeSlab
Im looking to replace my fuel pump on my Johnson 18hp outboard I believe the outboard is from the late 60's. The number on the back of the pump is 304089 I see from some other posts I've read that there is a newer model number for fuels pumps that will work for the older outboards. Which model number do I need to look for? Thanks for any help!
JoeSlab
Re: Johnson Fuel Pump
Would any of the sierra fuel pumps work on my outboard? They seem to be a little cheaper and the only replacement pumps I've been able to find based on the model # I have are around $100. I don't know much about these things and I don't have alot to spend so I want to be sure if I order a pump its going to work. Thanks for any help...
