Re: Johnson GT 150 1988 model..... been sitting for quite some time
The enemy of a stored engine could be any dried fuel that may be inside the carbs. This fuel gel, once dried, clogs fuel passages and jets so that the engine won't run properly. Probably best to just try to start it and see how it runs. If the engine was properly put away for long-term storage, it could be just fine. You'll know a soon as you start it. Good idea to toss the old fuel-complely drain the tank. I'd suggest you also change the lower unit gear oil. Once started, check the telltale closely. Possible the water pump impeller is weak. If you don't know the last time it was replaced-change it before you start it up. Once running, check the cyl head temps with a laser temp gun. Should idle between 143 and 155 degrees when sitting on the trailer. This will tell you if the two thermostats are working.
