Johnson GT Ocean Pro
Mikko
I came across with this motor, decal saying J10GTRSSS, power 11.2 kW, which is 15 HP. Does anybody know whether this motor is 10 or 15 HP? There should be some reason for model number J10, if it actually is 15 HP.
Chris1956
J10 indicates Johnson 10HP. The rest of the letters give production run and year. The year is 2000, according to the crowleymarine site.
Mikko
Yes, but it also says power 11.2 kW? I have heard that this GT means that 10 is derated to 15 as kWs say.
A marketing thing.-----A 15 hp sold as a GT 10 or powerful 10 HP.----Some lakes are limited to 10 hp.-----And the factory decals say 10 HP.----Easy to me.
saltchuckmatt
You can't take a 10 and derate it to a 15....you can derate a 15 to a 10 though. Can a 10 be made into a 15? Yes, with different terminology.
As marked, your motor is a 10 unless it's been modified.
Why do you care? Just curious.
Mikko
Nobody really knows if this GT is 10 or 15 as the decal says 11.2 kW (15 HP) I think this model was not sold in US (export family) and this is why people are confused. I care since I am about buying one.
saltchuckmatt
Well I should probably apologize then...never heard of a 11.2 kw cross-referencing a HP rating. And you are correct, reading the model number I would call that a 10 or actually a 9.9 because that was the "I don't have to register this boat" clause. So new one to me.
I have a GT 100....what's it's horsepower?
Race says to put a test prop on it... so I assume you will need a tach and a particular rpm for each range.
You certainly don't need to do it for me.
Cheers
