Re: Johnson hydro-electric
The leg is shifted electrically. There are 2 solenoids in the lower unit gear box. They require power in proper intervals to get reverse and neutral. Should be 3 wires coming up from the mid section. If you can find them we can guide you through the diagnostics. There is problem areas from the shift selector right down to the hydraulics. Proper diagnostics is recommended, as it can throw you for a loop. It even requires a specific gear oil (type "c")<br />Do you have a manual?
