Does anyone know the proper way to set the butterfly for the carb? (its a 1996 30hp)
I'll start by mentioning the boat is new to me, a little 14 foot lund that i bought and rebuilt over winter. All new flooring, gauges, electrical,water pump rebuild etc etc etc.
Anyways, After it got it ready for a test start last week, put the leg into a barrel and tried to start.....
Test 1- Wouldn't start. Investigated and getting no fuel from priming solenoid,so i repaired, also installed and gapped new champion plugs, checked compression 125psi cyl 1 and 120psi cyl 2 and now the boat starts but wont run without priming more fuel.
Test 2- Rebuilt the carb installed new kit, found previous owner installed the gasket between the bowl backwards. Reset the bowl float etc.Boat now starts easily and runs smooth but only stays running at about 1200 RPM AND with the high idle lever UP,which also slightly opens the butterfly of course.When i close the high idle lever the engine stalls, like the butterfly is choking the engine of too much air.
So my question is, should a closed butterfly valve actually have a small gap so the engine can run? If so is their a proper way to gap it?
