I recently bought a 3 HP JW-18. The motor runs great after a carb o/haul. I replaced the impeller as a maintenance item, but I have a question.
Water spurts out of the mating surface between the lower unit and the gearcase housing. The motor doesn't over heat, so my question is...does it matter? I can take it apart and seal it with a silicone gasket maker, but if it doesn't matter, I won't bother.
Thanks in advance
Thanks in advance
