Johnson key ignition codes dont match my Force Outboard Engine Help !!
playbuoy
Please help my 1984 bayliner capri with 1984 85hp Chrysler Force Outboard needed a new key ignition switch, but my shop only had a Johnson one which is a bit different. My wire colors dont match the instructions, can anyone convert this for me? is it possible? My bayliner ignition does not have an "A" terminal instead had a "B". I tried wiring once and had spark issues at the plugs, not sure if related but need to solve this first. Thanks !
On my engine my wire color codes are as follows:
Plain White -Magneto
Plain Yellow- Start goes to NSS
Plain Red - Battery
Plain Black- Ground
Plain Green- Choke
Plain Blue - Magneto
Letters on Johnson Key switch
M - horizontal terminal
I- vertical terminal
M- vertical terminal
S- vertical terminal
C- vertical terminal
A- vertical terminal
