Re: johnson lower unit oil replacement
Alan,<br /><br />You fill it from the bottom to prevent any air pockets. Not sure from your post if you are trying to reuse old oil. For the cost, I'd just use new. <br /><br />You have two options when replacing the oil 1) Purchase the oil in a tube with a tapered end that inserts into the lower plug hole (works, but can be messy if the tube slips) or... 2) Spend a couple of extra bucks and purchase the pump attachment that screws onto a jug of oil. The pump has a short length of hose that has a fitting you screw into the lower plug hole. Very convenient and much less messy.<br /><br />Good luck!<br /><br />Brew
