Re: johnson lower unit
Hi Bassmeister<br /><br />If the dripping oil appears after running iddle or slow in cold condition, it is probably just unburned twostroke oil, dripping from a drainhole. You can smell teh difference. The lower unit can leak at 5 places: Seals at propshaft, seals at driveshaft , drain og level screw or seal at shifting rod. A pressurize test will show where the leak is. Only the leak at propshaft and drain/level plug can be fixed w/o pulling lower unit.
