Johnson model MQ-13B What does the B mean?
F_R
A very often asked question. The trailing letter signifies any mid-year changes that were made-----IF any changes were made. Otherwise it means nothing. The parts book will reveal the changes, if there were any.
Nothing really.------MQ10 was the first year of production in 1964.----Yours is a 67 model.----The B might indicate a minor mid year change if there was one.-----Best to ignore the B at this time.------How is your motor running ?
Bream Killer
I rebuilt the carb and it runs great except no water so I am about to rebuild the lower gear case and water impeller. I was trying to get a gasket set and there were two different sets in the parts section.
Bream Killer
One thing I have had trouble with over the years is the fuel nipple. I have a drip there and I have changed fuel connectors till I am tired. They go on fine but will back off about an 1/8" and drip. Any ideas?
There was a change made in the propshaft oil seal.----So take yours apart and see what oil seal is on yours.---I can not see what parts are on your motor now.----My chrystal ball battery is low and needs recharging..---Sorry.
kbait
Hose connection on back side of engine fuel coupler?
F_R
OK, as it turns out, the "B" signifies a mid-year change was made in the prop shaft seal. I don't have the oem parts list, so I don't know if B means the one before or after the change.
