64osby
- Jul 28, 2009
- 6,826
Tracked this motor down and considering buying it. The owner is over an hour away and has been trying to help ID it but so far no luck.
No plate, He says the freeze plug has J2405753, with a block letter M inside a square on it. He thought it was a 1972, but now states a 1966. He states it's an 18hp.
I have been searching but can't find any match
He rattled off a couple of part numbers, 304761, which shows as a carb plate inner, and 308364, which shows as a mounting bracket. But I can't find the years for the parts.
He did send this pic
Cowl is broken and the transom mounts are broken, Before I bite I'm trying to see what it would take to put Humpty back together again.
