I have a 1996 Oceanrunner that seems to be missing at high speeds. It only does it sometimes and seems to do it after it has been running for a while. I tested the spark and at .05 gap cylinders 1,3,5 fire very strong and rapid. Cylinders 2,4,6 fire intermittently and not at all it seems sometimes. You can crank the ignition and hold it sometimes it fires and sometimes it doesnt. When it does fire on that side its not constant. Where as the other side is constant firing. Any suggestions. Im thinking the stator is shot? Thanks, Scotty
