Johnson outboard what year and hp
toolman1
I have a Johnson outboard model # VXL-11C<br />serial # 2544625. Can someone tell me the yaer and horsepower and what the fuel mixture is for it. <br /><br />Thanks for the help.
Paul Moir
Re: Johnson outboard what year and hp
VXL-11C<br />Make: Johnson<br />Year: 1965<br />HP: 60<br />WOT RPMS: 4500<br />Displacement: 70.7CID<br />Cylinder configuration: V-4<br />Weight: 225 lbs<br />Gearcase ratio: 20:23<br />Fuel/Oil mix: 50:1 87 octane gas to TCW-3 rated outboard oil.<br />Spark plugs: Champion J4C gapped at .030"<br />Lower unit oil: If electric shift, use only Bombardier 'Premium Blend' gearcase lube. Otherwise, use 'HiVis' or standard 90W outboard gearcase oil.<br /><br />Hope this helps!<br /> Old OMC Site
