Johnson Piston Installation
okintex
Im putting new rings in a 235 johnson. I forgot which direction the piston faces when i put the back in. (should have made notes huh?)
any advise would be appreciated
Chinewalker
Re: Johnson Piston Installation
The gently sloped side of the piston crown faces the exhaust ports. The abruptly sloped side faces the intake ports...
- Scott
reeldutch
make sure the oil holes on the rods are facing upward, so oil can drip in the wristpin bearings.
good luck
