Re: Johnson powerhead #s ('70ish), any way to know HP, 20 vs 25?
Hi Joakley,<br /> A few things to look for...<br /> Your serial number comes in as a late 1950s Johnson serial number. What color is (was) the motor block?<br /> I'm pretty sure the only real difference between the whole series of 22-cube OMCs (post 1968 redesign) was variances in the reed-stop height and minor porting differences. If your motor is indeed "restored" with the later powerhead, then it likely has the original 18hp carb and manifold which would in effect make your motor all of 18hp. The original 1958 18hp had a silencer over the carb intake, whereas the 1970-ish ones didn't. The later carbs were substantially larger and the old silencer wouldn't fit on them, and neither would the later carb fit on the earlier intake manifold.<br /> Also, does the cylinder head have a thermostat sticking above the top head bolts? They didn't add a t-stat until 1959. A 1958 cylinder head would not fit a 1959 or later motor block, and the '58 head would be required to allow a '58 hood to correctly attach.<br />- Scott
