I just picked up a 59 Johnson QD-20. Cleaned the carbs and put a fuel pump on it (so I could use the gas tank I have) and it was running decently. I took it to the lake fired it up and jumped in not realizing that when I jumped in the boat the prop went into the gravel. As soon as I put it in gear everything died. The pull start would not turn the flywheel. It was jammed on something.
I took it home and removed the starter where I turned the flywheel by hand. It was hard to turn but would turn. I then put the starter back on and the starter would turn the flywheel but it is now very hard to pull and is no longer a smooth pull.
I am am looking for suggestions on what could be bound up. It seems to be something on the drive shaft. I took the flywheel off and could not find any interference. Compression is good in both cylinders.
I tried to take the lower unit off today but it would not come apart from the shifting lever. Is this normal? How does that drive shaft slide out of the motor mount?
I have gotten it to start for about 2 seconds twice since the incident but it instantly dies.
