Johnson rewind spring interchange
evesdropper
1958 QD-19 with broken rewind spring. Johnson part catalog says 41-197. None of the local shops seem to be able to find that spring in thier databases. Sierra part number for this spring is 18-6501 and is the same as the spring for the 35hp model of later years.
So, the local shop does have a NOS Johnson spring for the 1957 35hp. Could it be assumed then that it would fit my 10hp since Sierra lists the same spring for both?
I would just buy it from the iboats store but it is out of stock. Thanks for the help.
Mike
tashasdaddy
Re: Johnson rewind spring interchange
they used the same parts in many motors back then, recoil spring would be one of them.
