Thanks to anyone that can help. I will give as much info as I can.
I have a 1994 johnson outboard. 25hp. j25rerc
the problem is that the engine surges or sputters when trying to get on a plane.
have cleaned and rebuilt carb
changed plugs..both were equally dirty(oil,carbon)
changed fuel pump diaphram
changed fuel pump screen
compression 118,120
spark is good on both
This engine has a primer for cold start. pull it twice and it kicks right over. At idle plunger has to be pushed or it wont idle well. but when inreasing rpm it starts to spit and sputter. If you pull the plunger out a bit it smooths up and doesn't sputter as bad if at all. Not sure what else to check unless the primer assembly is bad. please help!!
compression 118,120
