Johnson Sea Horse td 20 5.5 hp, serial # 677986
ceugene
I have a Johnson sea horse motor td 20, it's serial # 677986, the family I got it from said it's a 5.5 hp. I would like to find out the year it was build, so I can have it for my records also, I would like to know where I could get a carburetor rebuild kit and a new water pump for this. Can anyone help with this information?
The TD-20 was built from 1946 to 1949.-------You may find that it has a " wobbler " type pump in front of the propeller and it is quite durable.----------------Try searching for parts here-----aomci------website.-------Lots of grey haired expertise there.
steelespike
These numbers 614,515 thru 698,874 are 1948. Some numbers may have been applied in late 47.
It appears that the later Gale 5 and E/J 5.5 may be based loosely on the TD power head with the same Bore and stroke.
1 15/16 X 1 1/2".
I do wonder if the Piston and rods may be refined versions of the TD components. The 8.84 cubes for all 3 just seems too coincidental.
I do know that some internal clearances are shared between the Gale and OMC machines.
I know the TN series shares Mags Not sure about how many TDs.
F_R
It is 5hp., not 5.5hp It is totally different than any Gale, except for the magneto. That said, there is no such thing as a carburetor kit, except possibly a kit put together by one of the aomci hobbyists. A guy named Lloyd at the aomci Ask-A-Member website www.aomci.org makes some carburetor parts. Brian Wilcox makes water pump impellers (properly called a "rotor"). [FONT=&quot]email Baron0418@att.net. please note the b must be a capital. [/FONT]
steelespike
I have a copy of the Johnson Motors General Instructions manual good for the TD,TS,TSL,TDL
Suitable for reference not display. If you want a manual PM me your address.
