Johnson serial number help!!
Status
Not open for further replies.
J_parker1999
Hi every one I'm new to this forum but I've found a lot of useful information! I have located the silver quarter size tag on the top on the motor. It reads J3707606 I can't seem to find any information on the serial. I do know that the hood of the motor says 65 hp it's a 3 cylinder and it has the phrase "mean machine" near the lower unit on both sides. From what I can figure out its a 72 or 73 Johnson stinger 65hp but I would like to get the exact year. Any thoughts? Thanks!
Vic.S
Re: Johnson serial number help!!
You need the model number
Thats not the number......... Its not always on that plug.. I belive it is for Evinrudes ( mine is ) but may not be for Johnsons .
The number you need is the model number and should be on a plate on the ( port side usually) transom bracket
numbers for a ' 72 are 65ESLR72, 65ES72, 65ESL72
and for a ' 73 are 65ESR73, 65ESLR73, 65ES73, 65ESL73
emdsapmgr
model identification 2.jpgUsually on these older models, the factory stamps both the serial number (which is what you have given) and the model number-which is the number which tells the year-on the casting plug. As an example, see the attached pic of a 1975 engine. Any chance your plug has additional info?
F_R
I can tell you that serial number 3,669,313 is a 1972, and 3,859,623 is a 1973. So your number 3,707,606 is somewhere in between, making it a 1972 or 1973. But you already figured that out.
So.....Is it Hydro-Electric shift (1972) or Power-Shift (1973)?
EDIT: Deleting incorrect information.
seahorse5
If it has a red plug connecting the boat harness to the engine, it is a 1973 model. If it is yellow or black, it is a 1972
Island Pilot
How about G4607066
I can’t read model plate. Was told it was a 2004 commercial 40 Tiller Rope start long shaft when I bought it
GA_Boater
How about G4607066
Please start a thread of your own. You know you will be asking more questions and that's how to do it, by using your own thread.
Closed.
Status
