Johnson Shear pin
I B Dead Eye
(1954 Johnson Sea Horse QD15 10hp) What are the dimensions of the Prop Shear Pin?
kfa4303
Banned
Re: Johnson Shear pin
Hello I B. Welcome to iboats. I forget the dimensions of the shear pin right off hand, but you can simply take a drill bit and select the size that fits correctly into the shear pin hole. I wanna say it's 3/16" or 1/4". Here's a handy link that you can use to give the motor a tune up from top to bottom as well as a link to the pins themselves.
Evinrude Johnson OMC 0307949 - Drive Pin @ MarineEngine.com
Johnson
F_R
Depends on whether it still has the 1954 propeller on it. That took a 3/16" dia x 1-3/16" long Naval Brass shear pin. 1956-1960 motors took same size, but Stainless steel. 1960-up propellers take a 3/16" x 1-3/8" long Stainless steel. Heck, check the length of the slot in the prop and use the longest one that will lay in there.
EDIT: 307949 is the longer one
EDIT EDIT: Short brass one is part number 301923. Short stainless one is 203663
I B Dead Eye
Thanks guys, for your quick reply. I should have thought of using the drill bit to size it. The motor has the original propeller. The whole engine looks original as well is the boat a 1954 Cadillac aluminium boat. A pretty sweet setup.
