Re: johnson shift rod
On my 85 120 evinrude, no. Well, maybe if the powerhead and all the upper covers/cowls came off first. It's eccentric/bent where it comes through to the linkage. I'm guessing you need an impeller/water pump kit if you're asking about the linkage/gearcase. Mine got messed up when I did my water pump, had to drop the lower unit 3 times to reset it. What's the big deal???
