Johnson Starter
9711waving
I am trying to revive a 1981 Johnson 90 HP. It has not been started for about 4 years. It was last used in the bays of Texas. We pulled the plugs and put some oil in the cylinders and let it sit for a week. After a week, we then hand turned the motor, with the plugs, out for several minutes. It turned easily. We then, with the plugs still out, gave it a few shots with the starter. It turned with no problems. The pinion gear stayed up, but I think that is a different issue. We then put the plugs back in and tried it. The motor would not turn. I checked voltages on the solonoid and starter and they appear to be okay. I pulled of the starter and it appears to be a little hard to turn. Unfortunately, I don't know if it is supposed to be a little stiff.<br /><br />All opinions will be greatly appreciated. <br /><br />Have a great Holiday Season<br /><br />Del
papasage
Re: Johnson Starter
your voltage is good but is your amps good . that is what it takes . a week conection willmake the starter not turn right.it takes more amp to turn a outbord than it takes to turn a big v8 auto motor
DHPMARINE
Re: Johnson Starter
Copano,<br /> <br />You can bench test the starter and see if it spins faster.Someone in your area probably rebuilds car starters.Take it to him,and remind him it is marine use.<br /><br />DHP
