warpedrotor
- May 13, 2007
- 16
Just acquired a Johnson TD 20. Has compression and good spark, I took the carb apart and it's a mess. I have a spare 9.9 carb that has about the same bore. I can build some flanges to adapt it to the intake, but I am wondering about these small lines that run from the carb to a Y shaped connector on the front of the crankcase, one line goes up under the flywheel, another seems to have nothing connected to it, either it had some type of valve or tube connected to it. The middle of the Y shaped connector part has a hole in it with a rotating part visible. What is the purpose of these tubes?
