jeremyeasen
- Jun 20, 2002
- 72
i have a 1991 johnson 115, just replaced the tilt cylinder and 3 weeks afterwards the threaded fitting going into the top of the middle tilt cylinder began a small leak. it is not coming from around the threads, but between the tubing and the threaded fitting. replaced the O-ring several times thinking it wasnt seating right, but it still is leaking from around the tube. i havent got the OEM O-ring, but have visibly matched up with the one the mechanic installed after the cylinder replacement. will a very small size difference in thickness or diameter prevent it from sealing correctly? the replacement appears to be identical.
