Johnson V4 115hp
Limey
OMC Palse Pack Problem<br />i just acquired a johnson 115hp two stroke outboard it has been sitting for 4 years outside in all weathers.<br />When i first tried to start it nothing happend so did some reading and was told about the kill switch but could not locate the black wire with yellow tracer so disconnected wire not related to the motor and i could hear the palse pack pulsing after several try's at startig smoke started to come from the pack. i have got a new pack but before i install it can anyone tell me if it was probably a problem with the pack or was it likely to be a problem with something else to cause the pack to smoke.<br />any help would be appreciated. :confused:
crazy charlie
Re: Johnson V4 115hp
I would start by trying to turn it by hand.Pull plugs first and squirt some fog or penetrating oil in each cyl.Charlie
JB
Moving to Johnson OUTBOARD troubles.
