The impeller will get replaced as preventative maintenance but yes I do crank with the ears on. I was able to buy a new compression tester today. These readings are engine cold, all plugs out.
Upper Left: 115 Upper Right: 110
Lower Left: 113 Lower Right: 107
They don't look too terrible in my opinion. Factory spec is 125 correct? I fired it up today for a second after the compression test and it seems to run smooth. From what I've read, part of the reason these engines break piston rings is due to carbon build up so I should probably due a decarb right? Whats the preferred method and what do you guys use for it, Seafoam? Is there any other preventative maintenance I should do other than decarb, spark plugs, gearcase oil, and water pump? The VRO has already been taken off but I plan on getting the correct premix pump for it.
As always I do appreciate the help
