Hello i have a johonson V4, the problem i am having is when you press tilt and trim button you can hear motor going but after about 30 seconds pump cuts in and lifts motor same when coming down it has the two rams some one said it could be low on oil i have checked un done screw and a bit of oil come out, also i was told might be air in the system how do i get that out also is there anything else it could be when rams come on it lifts it up real good. any help would be great.
