Re: johnson wiring
IF YOU GET THE RIGHT KEY SWITCH YOU WILL HAVE TERMINLS LABELED WITH AN M,M,S,C,I OR A,B THEY HOOK UP AS FOLLOWS.<br />M-BLACK (GOES TO GROUND)<br />M-BLACK WITH YELLOW STRIPE (KILL CIRCUIT)<br />ON THE TWO M TERMINALS IT DOES NOT MATTER WHICH WIRE GOES TO WHICH ONE.<br />S-YELLOW WITH RED STRIPE (STARTER SOLENOID)<br />C-PURPLE WITH WHITE STRIPE (CHOKE)<br />I OR A-PURPLE (ACCESSORIES)<br />B-RED (BATTERY POSITIVE)<br />SOME KEY SWITCHES WERE 5 TERMINAL AND SOME WERE 6 IF YOU DO NOT HAVE ONE OF THESE WIRES IT WILL BE THE CHOKE WIRE .WHICH WILL MEAN YOU EITHER DON'T HAVE AN ELECTRIC CHOKE OR IT RUNS OFF A SEPERATE TOGGLE SWITCH AND IT WILL NOT MATTER IF YOU LEAVE THAT TERMINAL EMPTY.
