Ok, the Johnyrude is runnin good lets get that down.... yet I'm running hotter plugs than I should. I don't idle much mostly WOT and some midrange. Is this gonna hurt my motor in the short or long term? Shop was out of JC4's so went a plug hotter. Also I'm finishing up my wiring on my ignition switch. What guage wire should I use coming from the battery and to the starter? Also what guage should I use all inbetween from the actual switch to solenoid? Also the two wires coming from the armature plate actually shut off the motor. Can I splice these two wires together and shut them both down? My ignition switch only has 5 terminals and I was just gonna put them both to that one terminal..... Sound ligit? Thanks a ton guys.
