The big fisherman
- Mar 14, 2005
- 1
I have a 1995 Johnson 9.9 and the problem is when you start up it always fires right up, then you get going and the engine will rev out fine and run full throttle. It will run like this for awhile and then it just shuts down to about an idle. It never misses or anything. We have tried a new fuel line, different tank, new plugs. Any one have any other suggestions. Had at a repair shop which they put it in a tank for a few hours and it never does it. Only seems to do it when it is in gear. Many times it will go almost an entire day on the lake without doing it, then when you start back to load up you are only moving at an idle. Runs great even when it does this just won't rev up.
