Re: Johson charging rectifier
Hi all I made up the new diode bridge and mounted it, I am sure it will be O.K. This was the last job to finish after fitting a totally re-built powerhead.
Sadly the engine won't start; no spark! I have fitted and gapped new points and new plugs. magneto driver coil seems O.K. (reads 1.7 ohms on the 200 volt scale). flywheel magnets hold a big screwdriver in suspension. Ignition coils, primaries read 1.7 ohms (200 ohm scale) . Ignition coil secondaries measure 17.3 and 13.3 respectively (200K scale) Imention the scale as I am using a cheap Digitech Multimeter and it will not measure coil secondaries on the lower scales. Obviously one coil has shorted turns but I can't get a spark with either.
I would like to check the ac voltage output from the magneto coil but I have no idea what it should be, can anyone help? Also any other advice woul be appreciated.
This engine has not been used for 3 years and the ignition coils had only been fitted for 6 months and had about 8 hours running time. The engine seized, I let it cool squirted a bit of oil in the cylinders and it re-started. After 2 hours running it rattled like hell so I dismantled and a mate re-built the powerhead, hower the coils were O.K. at the time I dismantled it The coils are cylinder head mounted.
Sorry about the length of this diatribe but a lot of it seems relevant when diagnosing. We are nearly half way thro the 1st of Jan now in Australia so I reckon many people will be just stating to celebrate.. Have a great time and a safe, healthy and happy new year.---------Macengine
