Hi Rick that link you have posted no longer works buddyOriginally posted by rickdb1boat:<br /> Michigan Prop selector says a 9-1/2" X 10" pitch is the standard prop. If that will work for you depends on the actual weight of the boat and load. There aren't too many pitches offered for that combination...<br /><br /><br />3 Blade 9-1/2" X 10" RH #012111 MICHIGAN MATCH<br /><br />3 Blade 10" X 7" RH #012112 MICHIGAN MATCH<br />(Would be for a heavy load)<br /><br /><br /> web page
