Been boating for years, mainly inshore fishing, and moved to Georgia recently and purchased a jon boat (my first flat bottomed boat).
Had an interesting experience I wondered if anybody else has had, or can comment on.
Boat is a 12' tracker boat with a 1998 Johnson 4stroke 8hp. I purchased the boat used and I can say that this motor is probably too heavy (Coast guard plate says 6hp max, and I imagine that is with a lighter 2 stroke).
Anyway, because of this the boat is fairly backheavy but with two people in it and the motor trimmed all the way in it planes ok and handles fine.
HOWEVER, I decided to take a spin solo for the first time with the motor trimmed all the way in. At full throttle I felt I was barely touching the water at all, and was screaming along. As I was trying to make a high speed left turn though, I felt that it was not turning/handling very well, felt like it was almost skidding instead. Then WHAM, I think the right edge caught, and I roll 45 degrees to starboard, take on 30-40 gallons of water over the side in an instant and almost fall out. I would have sunk if I hadn't given it full throttle and made my way to shore at 5mp with the bow 6 feet in the air and the back full of water to beach the boat.
Am I just an idiot for thinking that a flat bottomed boat should be able to turn at high speed? Or do you guys think this is a symptom of a my trim setup/too much motor. Suffice it to say I will NOT be making any high speed turns in a flat-bottomed boat ever again.
Thanks,
John
Thanks,
John
